LR2.tire pressure sensor
Old Oct 16, 2021 | 10:20 AM
merlinj79's Avatar
It may be able to learn OEM sensors on it's own....
Shut the car off for 15 minutes.
Drive it, maintain 30+ mph for at least 15 min
Park the car for 15 min
The car is basically looking to see which four TPMS sensors are following it around. Google says this won't work for the spare tire if you have TPMS on that (I don't).
Old Oct 16, 2021 | 01:20 PM
flybd5's Avatar
Looks like you are correct except for the speed.
"If a new tire pressure sensor is fitted on any 'running' wheel, the software can learn the new sensor identification automatically when the vehicle is driven for more than 15 minutes at a speed of more than 20 km/h (12.5 mph)."
It will not detect anything on the spare tire because there is no TPMS antenna in the trunk.
So no reprogramming with JLR SDD is required.
Old Oct 16, 2021 | 10:09 PM
mvan231's Avatar
Try disconnecting the car battery for a while, touch the cable ends together, then reconnect. Let it sit for a while and turn the car. Maybe the computer reboot will clear it up.
I'll have to give that a shot to see if it helps thanks a ton
Old Oct 26, 2021 | 07:46 AM
guy's Avatar
guy
Actually, on the 2014 model, tpms is on the spare too.
cheers!
Old Dec 6, 2021 | 04:44 PM
flybd5's Avatar
cheers!
Yes, but there is no TPMS antenna in the trunk so it won't tell you if the spare is losing pressure.
Old Dec 13, 2021 | 04:24 PM
guy's Avatar
guy
Not quite accurate. On my model I had a message in the message centre stating the spare tire pressure was low.
I'll play with it in the sunlight and give you a picture.
Old Dec 13, 2021 | 04:30 PM
flybd5's Avatar
I don't have that feature. Is yours an HSE? Mine's an SE, maybe that's why.
Old Dec 14, 2021 | 01:58 AM
ThorInc's Avatar
His is a 2014 HSE model (in his sig), my model year is 2008 as I believe yours is?
Old Dec 14, 2021 | 08:06 AM
flybd5's Avatar
Actually, on the 2014 model, tpms is on the spare too.cheers!
Yes, but there are different models within the year. It's either SE or HSE. It's on your rear hatch.
Old Dec 14, 2021 | 09:21 AM
merlinj79's Avatar
My 2008 SE doesn't have the spare TPMS either. Wish it did, that's actually useful, even I forget to air that thing up.
journeyman
Nov 20, 2023 04:13 PM
Equinut
Oct 28, 2019 10:48 AM
thehun
Oct 5, 2011 11:21 PM
robertconstable
Freelander
Jul 16, 2011 12:23 AM
rkrainak
Oct 11, 2007 09:15 PM
