Narrowing things down 2008 LR2 3.2
Ok, now we are getting somewhere. All three of those codes likely point to a bad Manifold Absolute Pressure sensor (MAP). They are widely available and run from $21 for a rice rocket special to $90 for OEM.
But MAP did not cause the AC to stop blowing cold.
I generally prefer to address issues one at a time. The codes you posted are MAP sensor-related. I suggest you take care of that and then we look at the other symptoms. It's the only thing I can do for you since I do not have the car here with me.
Once you fix the MAP sensor, I would suggest checking the refrigerant charge and using a dye to look for a leak as a staring point.
The previous owner did not tell me when the Thermostat was replaced. That maybe something there. I thought it would be ok if it runs fine all the other times except when at an idle with the AC on? Would low refrigerant cause it to get warm and the car to overheat?
