New AC/Heater Blower Motor Installed
Old Apr 30, 2026 | 10:45 AM
  #21
LR2driver's Avatar
Originally Posted by flybd5
Are you sure the PWM is generated before the fan module, and not by the fan module itself?
Based on everything I've read, the PWM signal comes from the ECU (pin 8) through a small purple wire to the fan module. I will backprobe the ECU with an o-scope to check if there is a square waveform. I discovered that my OBD2 scanner has a bi-directional control to activate the fan, so that makes testing a lot easier.
Best guess (before testing) is that the ECU is putting out a good PWM signal and I will need to trace the control wire to figure out why the signal isn't reaching the connector to the fan module. I've watched a couple Youtube videos where they found this thin signal wire was frayed/broken.
mr4x4
Oct 22, 2021 11:14 AM
Cirrus
Oct 21, 2021 09:50 PM
flybd5
LR2
Mar 20, 2020 07:01 PM
olywa
Nov 28, 2015 04:47 PM
AuZZZie
Jun 5, 2011 09:02 PM
