Opening the rear hatch without removing the key from the ignition?
So I purchased my 2012 LR2, and I can't figure out how to pop the rear door open without shutting the car off, and them removing the key from the ignition to use the button on the fob.
I feel pretty stupid, and I don't see anything in the manual about it...... how the heck do I do this?
on my 2008, if you close all the doors and then hold down both the lock/unlock buttons simultaneously for a few seconds (until the lights flash) this sets up your fob to unlock all doors with one push. This should also apply to the unlock button on the dash as well. Pushing it once should unlock everything, allowing you to access doors with the vehicle on.
let me know
let me know
I am not familiar with the 2012 LR2 but I can't see it being significantly different from my 2008. Have you looked under the rear hatch handle, just above the licence plate holder in the middle of that latch/handle? Should be a rubber covered latch. If you have one but it does not open the rear hatch when unlocked, then the handle may need to be replaced. I replaced mine on the 2008 because the toggle was corroded, it was an easy job and the OEM switch/latch was very reasonable to buy.
Monmon (11-05-2020)
Hi, thx for the reply. It works fine opening it from the outside, I'm wondering how I open it from the inside with the key in the ignition.
I was pulled up outside a business the other day, and needed to open the hatch for someone who had their hands full, but I needed to remain in the driver's seat with the engine running.
