Poor Starting Freelander 2
Old Nov 13, 2024 | 06:05 AM
HScarrott93's Avatar
Default Poor Starting Freelander 2
Hi all, I'm new to the forum, so appreciate any help in advance!
I have a 2012 FL2 with 80k miles (of which Ive owned for the last three years).
It has an issue with starting first thing in the morning. This is worse when its cold, but can happen in all weather really - only affects the first start of the day, when left overnight. Any other time it starts fine. It either cranks for 7-8 seconds, then starts. Or cranks, splutters, coughs and starts with a puff of white smoke out the exhaust - doesn't sound healthy at all.
It has been to a number of garages, who are all stumped. Shows no error codes (even on land rover diagnostic systems). Garages are replacing things by process of elimination, but nothing has made the slightest difference.
The following has been done in the last 12 months - new battery, new LR fuel filter, 4 brand new Bosch fuel injectors, 4 new glow plugs, new glow plug control module, new cambelt, extra earth from battery to gearbox & another to starter motor, non return valve added to fuel line, new camshaft sensor, new crankshaft sensor, EGR delete. Fuel pressure has been tested an is ok. Compression has been tested and is ok.
Here is a link to a video of how it starts.
Hopefully someone has a similar experience and can shed some light. Spent lots of money on fixes, but nothing Sad
Many thanks
Old Nov 13, 2024 | 10:30 AM
merlinj79's Avatar
This site is mostly North America people, and we mostly have gas (petrol) engines.
There's a UK site where most of the participants have diesel engines...
https://www.freel2.com/forum/index.php
Old Nov 13, 2024 | 08:49 PM
flybd5's Avatar
That doesn't look like the dash display of a 2012 Freelander 2/LR2 diesel. At any rate, if the temperature is cold, never try to start it right away in the morning or anytime the engine is completely cold. Keep your feet away from the pedals and only turn on the electrics with the start switch. Wait a bit for the glow plugs to warm up and then start it. In fact, if you wait a bit, doesn't the "Check engine" warning light turn itself off? That would be a sign it's a glow plug warmup issue.
In addition, if your LR2 has the diesel engine heater option, use it.
Old Nov 14, 2024 | 09:02 AM
guy's Avatar
guy
Adding to flydb5’s response, there is one thing I do now for all my vehicles…. first turn on the ignition without turning the engine over.
The value in this is “pre-charging” the fuel rail/system and activating all necessary modules. Following the completion of all startup sounds (whirrs, dings, clicks), then depress the brake pedal and touch the start button. Also, Diesels need the action of the glow plugs in the cold.
Cheers.
Old Nov 14, 2024 | 09:07 AM
flybd5's Avatar
Cheers.
I could've sworn that's what I said, but I am becoming an old fart Marine... 🤣🤣🤣
Old Nov 14, 2024 | 11:51 AM
guy's Avatar
guy
oops…
Old Nov 15, 2024 | 06:15 PM
LR2driver's Avatar
Sounds like some condensation may be building up overnight in the cylinders.
You didn't indicate if you park outside overnight and how cold it gets. It would be interesting to see if your morning start is smoother after parking overnight in a garage that does not get much colder than 60F/16C.
Old Nov 15, 2024 | 06:17 PM
flybd5's Avatar
Wouldn't that also imply no need for extra time for the glow plugs to warm up?
Old Nov 15, 2024 | 06:22 PM
LR2driver's Avatar
I was going for root cause analysis.
Dentaldave
Oct 24, 2024 03:58 AM
Bullevard
Sep 23, 2023 05:15 PM
tanman1234
Sep 24, 2021 10:34 AM
GSPVX
Freelander
Feb 27, 2021 11:28 PM
Tristan Stumpf
Jan 11, 2020 06:40 PM
