Replace coolant radiator
Old Oct 2, 2022 | 07:27 PM
villegente's Avatar
3rd Gear
Default Replace coolant radiator
Hi,
I need to replace the coolant radiator of my 2009 Freelander 2 2.2 TD4 SE (Auto).
id you you know where I can find a tutorial to help me to do this ? Is their a solution without removing the airconditionner radiator ?
Thanks for your help.
Old Oct 3, 2022 | 12:32 PM
merlinj79's Avatar
IIRC you can do it either by removing the intake manifold or the front bumper. I think it's possible without disconnecting the condenser and losing your charge.
This site is mostly US, we mostly have the 3.2 i6 engine in early LR2's. There's more info about the diesel models on the Brit freel2 site...
https://www.freel2.com/forum/index.php
Old Oct 4, 2022 | 05:45 PM
flybd5's Avatar
Originally Posted by villegente
Hi,
On the diesel models you have to remove the cooling fan motor and shroud, the bumper armature and the charge air cooler. You then detach the coolant hoses and take out the radiator. Reverse to install. It's much easier than on the 3.2L gasoline model.
If you download the service manual for which there are a few links here on the forum, you will find the instructions on page 963, "Engine Cooling - TD4 2.2L Diesel - Radiator, Removal and Installation".
Old Oct 4, 2022 | 05:49 PM
flybd5's Avatar
Originally Posted by merlinj79
IIRC you can do it either by removing the intake manifold...
The diesel model's intake manifold is much smaller than on the gasoline model and thankfully doesn't have to be removed to get to the radiator.
me 2
Jan 8, 2022 06:26 PM
piperff
Jul 7, 2019 10:56 PM
themdg
Apr 11, 2018 01:00 PM
MaverickTye
Freelander
Jun 2, 2010 11:59 AM
dc10freighter
Aug 19, 2007 10:14 PM
