Replacing Front Hub Assemblies—HELP
Old Nov 11, 2018 | 07:48 PM
Regret1990's Avatar
Default Replacing Front Hub Assemblies—HELP
Trying to remove my front hub assemblies and I can’t get it to disengage from the housing it sits in. Not sure of proper terminology, so sorry for any confusion. Tried a pulled but it just pushed the drive axle out of the splines of the hub.
Old Nov 11, 2018 | 09:29 PM
If it's like the lr3 there are bolts going in from the back side and a BFH is needed to persuade it out
Old Nov 11, 2018 | 09:32 PM
Regret1990's Avatar
i don’t see any additional bolts anywhere on this assembly. I don’t have a slide hammer but we’ve been using BFHs, a puller, Pb blaster and an assortment of other things.
This is the current view from behind the assembly.
Old Nov 19, 2018 | 08:32 AM
Gnomadf's Avatar
You may have to remove the knuckle and press them out, this looks very much like a Volvo bearing and since the LR2 shares a chassis with the S80 it makes sense. The problem is that they are tricky as heck to press back in, if you press on the hub you destroy the new bearing. You have to build up around the outer edge of the bearing so the pressure is on the outer race, not the middle, it's a bear of a job.
Alternately, you could try freezing the bearing and heating the knuckle. If you can get the bearing to contract from the cold and the knuckle to expand you can possibly slide the new bearting into the knuckle. This worked with BMW motorcycle rear end bearings, so it might work here.
swandrum1
Aug 12, 2018 04:58 AM
Dv8er
Apr 27, 2017 03:15 PM
Externet
Aug 26, 2013 06:45 PM
marshman442
Jun 15, 2011 07:12 PM
AK Rover
Jul 11, 2010 08:57 PM
