Towing and Trailers
Towing and Trailers
Ok everyone, I'm going to be purchasing a 6x10 tandem axel, v-nose, enclosed motorcycle trailer. My question is this...of those towing, what are you towing, weights, and handling characteristics? I'm really interested in the handling of the LR2 while towing. Is there anything that I should be aware of, problems, etc? I have the OEM electrics installed and will be installing a Hidden hitch once the vehicle is back in the continental US.
I don't think I want to go larger than 6x10 tandem since it will be about 1200lbs plus a 1000lb motorcycle and gear, or misc furniture and whatever else the wife decides she can't live without.
Of those using the Hidden Hitch, Curtis, or Draw-tite... what size rise/drop ball mount are most using?
Thanks for any input or additional info...
Bill
Bill
The cutting is the main reason I'm staying away from the OEM hitch, well that and the extra $800+ for the OEM hitch and install. The hidden hitch (and others) is a self install, no cutting, no bumper removal, etc. I have the OEM electrics installed and I'm getting them activated at next oil change.
Big thing I wanted to know is what others are towing and how the LR2 handles while doing it. I'm trying to stay with an enclosed trailer that is less than 1000lbs. Didn't see an entry in the specs until couple days ago about the unbraked trailer weight of about 1700lbs. So couple of the single and tandem trailers I;m looking at are 900-980lbs and keep me in the price range I want to stay in. Thanks for the input.
Answering my own question
Guess I'll answer this one myself. Got a 6x12 custom motorcycle trailer as a Christmas/Anniversary present http://www.colonycargo.com/listing/574. At first I was concerned about the size of the trailer with the LR2. Started in FL and drove to my parents house in Southern West Virginia. Other than gas milage, the LR2 handled the trailer with about a 500 lb load with no problems (even with 30-40 mph wind gust. Used command shift in the mountains to better control the shift points. Pulling into WV and it was snowing and there was a good bit of snow on the roads. Just before my parents house I stopped at the bottom of a sizable hill that will sometimes trip up the 4x4s, but the LR2 pulled the tailer up the other side with barely a slip of the wheels.
Went with the OEM electrics and a Hidden Hitch. Hitch installed in 1/2 hour and fits very well.
Hidden Hitch
I used the fit guide at Hidden Hitch to get the model number (87575). Then researched online to get the best price ($ 140 - 150), which at the time was etrailer. I liked the Hidden Hitch because it had the mounting tab for the tow kit plug. Also there is no cutting of the bumper to install it.
I did the same for the OEM tow electrics ($311). Found the part number and searched online. It's over $1200 for the OEM receiver and Electrics through LR...not counting the labor cost. Saved over $725 doing it myself. I install the electrics just before taking it in for maintenance and had LR activate the kit. They charge me for 1/2 hour labor to activate.
So saving over $1000 is a no-brainer and the install of both was pretty easy.
Will the OEM harness also run the trailer brakes? Sounds like not.
BPUtah says this PN VPLFT0003 has superseded the old PN for 2008, but they also say the new PN does not have a 7-pin connector.
Has anyone added a 7-pin adapter and brake controller to the OEM harness?
I tow both small watercraft (4-pin) and a small camper (7-pin w/ brakes).
Thanks
Thanks
OK, I got the hidden hitch.
Looks like I'll have to install the OEM harness and then add an adapter kit with a 7-pin and brake controller. That should piggyback on the 4-pin connections plus some extra wires for brakes.
Still not sure if the VPLFT0003 harness supersedes the original 2008 harness (LR003108G).
