Transmission jump while accelerating
Old Nov 24, 2020 | 04:24 PM
Charles Bridges's Avatar
8th Gear
Default Transmission jump while accelerating
Hey guys . I thought I had a misfire but after replacing coil packs and overhaling the injectors I have the same symptom. When I accelerate from zero to 50mph I will get 2 or 3 major stutters. I now think it may be tranny related. I did change the vss recently. I could just be low on tranny fluid. Any body ever had this issue. I can't believe I'm the only one lol. Thanks
Old Nov 24, 2020 | 06:35 PM
flybd5's Avatar
What are the error codes on the computer?
Old Nov 25, 2020 | 12:59 PM
8th Gear
no engine light , no codes
Old Nov 25, 2020 | 01:02 PM
8th Gear
No engine light , no codes
Old Nov 25, 2020 | 01:58 PM
flybd5's Avatar
Have you checked the transmission fluid level? It's supposed to be a closed system. If it's low you have a leak.
Old Nov 25, 2020 | 08:49 PM
LR2driver's Avatar
You may have a code that does not turn on the engine light. Does your OBD2 scanner check all the modules, including the transmission module? The less expensive OBD2 scanners only see codes related to emissions.
Old Nov 26, 2020 | 04:52 PM
ThorInc's Avatar
Fuel filter genuine?
Nov15
Aug 5, 2016 01:12 PM
bamaboy473
Sep 23, 2012 07:13 AM
bobbydave
Jan 31, 2008 08:30 PM
endneu913
Nov 4, 2007 11:18 PM
Doak
Nov 27, 2006 11:54 AM
