05 LR3 Possible Bad MAF Sensor
Old Jul 13, 2019 | 05:52 AM
Abdulaleem IbnPeter's Avatar
4wd High
Default 05 LR3 Possible Bad MAF Sensor
Hi All,
I have an 05 LR3 4.4L with a P0172 and P0175 codes. I'm thinking it might be coming from a worn MAF sensor. Can anyone point me in the right direction on how to test and confirm mine?
Thanks In Advance
Old Jul 13, 2019 | 07:13 AM
DakotaTravler's Avatar
MAFs are often easy to examine visually. Pull it out and take a look at the small wires. They should be fairly clean, if there appears to be deposits you can try cleaning it with MAF spray cleaner (never touch the wires, they are fragile). If over 100k miles, probably just a good idea to replace it anyway.
The original MAF sensor is probably a Denso part, so if you do replace it you can save some money by getting the Toyota equivalent. Part number: 22204-22010
Old Jul 13, 2019 | 06:56 PM
4wd High
Truck's got 220K so i think I'm just going to swap it out. Thanks for the advice.
EastCoast
Feb 3, 2017 10:32 AM
Richard Moss
Aug 18, 2015 10:35 PM
DonRW2007
Dec 13, 2013 03:27 PM
Rover De Land
Aug 26, 2012 04:46 PM
ezikial4
Jun 28, 2009 08:26 PM
