06 lr3
Old Apr 5, 2021 | 11:38 AM
Noelle@666's Avatar
Default 06 lr3
Had a variation in my idle so my mechanic said to change my pcv valve. Did so and now it smokes n stinks terribly. Bought china pcv. Bought a second one and problem persists. Definatly pulling oil from crank case. I have ordered a new pcv from land rover and am waiting on part. Is there something i am overlooking or am doing wrong. Please help me. I am disabled and only get one check a month and cannot throw money at a hole in the floor... Thank you...
Old Apr 5, 2021 | 08:19 PM
DakotaTravler's Avatar
Make sure the air tube to the PCV is not cracked and its o-rings are in place for a proper seal. Also make sure the oil cap is installed and that the oil tube is installed fully. These vehicles are VERY sensitive to vacuum leaks. Also for testing you CAN operate for short durations with no PVC at all. Remove and plug both ends if you want to test.
Noelle@666
Apr 5, 2021 11:37 AM
zuke
Apr 19, 2019 05:56 AM
Jwehking
Jan 6, 2018 07:31 PM
Jeff Blake
Jun 6, 2017 02:29 PM
austinlandroverbill
Aug 23, 2015 01:03 PM
