Burning oil, what are the steps to diagnose?
Old Jun 4, 2017 | 10:47 PM
Jeff Blake's Avatar
Default Burning oil, what are the steps to diagnose?
Newly rebuilt engine, followed the overhaul manual to the T, double checking all the tolerances.
I drove 1,100 miles, towing, and noticed I'm down about 3/4 of a quart of oil. I was about 1/2" above FULL line before, and ended up barely above FILL line after the trip. No leaks.
Thanks for any tips.
Old Jun 5, 2017 | 01:00 AM
MrValingo's Avatar
Continue to monitor. A brand new car can consume 1quart per 1000mi and be considered within spec
Old Jun 5, 2017 | 07:37 AM
abran's Avatar
Did you hook up PCV hoses correctly/ install a PCV valve?
Also, why 1/2" above full? Maybe being over filled has something to do with it. Crank can cause cavitation and oil frothing which may be causing too much oil to vaporize.
Old Jun 5, 2017 | 11:48 AM
Jeff Blake's Avatar
Yeah I have the christmas tree PCV separator in the passenger valve cover. No separator driver side. As for the hoses, they only really go on one possible way so no issue there.
Accidentally overfilled it, I was used to changing the filter along with the oil, but last time I didn't replace the filter, overfilled, and was too lazy to drain some.
I need to check the rear seal again through the inspection hole. hopefully I don't get showered in oil.
Where else could the oil go?? Past the piston rings is the only thing I can think of, but those are all new and I measured them religiously.
Old Jun 5, 2017 | 01:14 PM
abran's Avatar
Make sure the gaps on the rings were staggered?
Old Jun 5, 2017 | 01:15 PM
Jeff Blake's Avatar
Yeah I did that correctly when I rebuilt. They sure seemed like they could move around easily though
Old Jun 5, 2017 | 02:02 PM
OffroadFrance's Avatar
X1 .................. also run a compression test on every cylinder and compare to the pressures in RAVE. It takes a long time for a newly rebuilt engine to 'bed down' particularly new piston rings in new cylinder bores. A compression test will reveal any anomalies between cylinders and any lack of bedding down against the 8x design pressures.
Old Jun 6, 2017 | 02:29 PM
Jeff Blake's Avatar
Well, no way to check the rings without removing the heads and pistons... sooo probably not going to do that. I ordered a compression tester, that's worth a shot.
lrjon
Apr 12, 2015 02:37 PM
tacker
Jul 10, 2010 09:36 PM
javoli002
Oct 30, 2009 10:51 PM
javoli002
Defender
Aug 25, 2009 10:20 PM
doeboy
Sep 10, 2005 08:07 PM
