'07 50 mph shimmy
Old Oct 5, 2016 | 12:12 PM
Coleroad's Avatar
I had the problem. I changed the whole front end in one fell swoop. Both upper and lower ball joints, control arm bushes, inner and outer tie rods, and the sway bar end links. Then I only had to pay for an alignment once. The front end is set for a good long time now.
Old Oct 5, 2016 | 02:15 PM
EastCoast's Avatar
You might want to get the tires checked at a shop where they can check for damaged belts... my mechanic told me that he would occasionally see a tire that wouldn't balance up right no matter what they did, even with the Road Force system. Try rotating the front tires to the back to see if it helps.
dirtbag
Jun 3, 2015 07:51 AM
jeffh
Jan 20, 2011 12:35 PM
texmanmoore
Feb 21, 2008 07:57 PM
red rover 99
Sep 13, 2006 02:07 PM
anonimaus
Apr 6, 2005 04:40 PM
