16" steel wheels on an LR3?
Old May 1, 2015 | 06:58 AM
drowssap's Avatar
look at that; not only did you get one salesman from Lucky8, you got two.
Old May 1, 2015 | 08:40 AM
adamsrotors's Avatar
^ yet the product is unavailable to purchase...
Old May 5, 2015 | 12:37 AM
spiderman's Avatar
Default wheel offset
Originally Posted by adamsrotors
what does proper offset even mean
regarding wheel offset;
negative offset sets the wheel farther out. the backspace is reduced because the mounting surface is closer to the inside of the rim. this allows a wider tire or a wider stance.
positive offset sets the wheel closer. the backspace is increased because the mounting surface is closer to the outside of the rim. this allows a tire to be "tucked in" into the wheelwell. of course, you need the room around suspension parts for clearance.
zero offset means the mounting surface is in the same line as the centreline of the wheel.
bolt pattern is one thing, but there are many other aspects to consider
Attached Thumbnails 16" steel wheels on an LR3?-atv-wheel-offset-explaination.jpg   16" steel wheels on an LR3?-backspace_offset.jpg
Old May 5, 2015 | 12:50 AM
I was being facetious.
there is no "right" in this case...we're doing something different, custom, non-factory. stock specs don't pertain here really.
jycsalas
May 23, 2019 03:02 PM
Camtait95
May 26, 2014 09:48 PM
cscmc1
Jan 31, 2011 09:38 AM
kpl1228
Nov 20, 2010 11:05 PM
