1st post- Please help
Old Dec 5, 2013 | 03:24 PM
Atticus_6147's Avatar
Default 1st post- Please help
Hello,
I am new to the forum and I hate to start off on a bad note but I need some help and I'll be honest, I haven't done a whole lot of searching yet. I promise I'll be better in the future.
I recently purchase a 2006 Land Rover LR3 6 cylinder. Love the truck but recently, when I start the truck, it will fire up and then die. However, if I start the truck and give it a little gas, she will idle and run without any issues.
Has anyone experience this problem before or know how to approach it?
We have some bad weather heading our way and I just want to make sure I do not get stuck somewhere.
Thank you in advance.
Old Dec 5, 2013 | 03:41 PM
Scope's Avatar
Hi, to be honest I do not know much about lr3's but I have read that the injectors stop up
pretty easy and need cleaning at the fuel rail.It may be worth searching.
Old Dec 5, 2013 | 06:35 PM
roverguy7's Avatar
Step one is to pop the intake tube off of the throttle body, and check to see if there is any significant carbon build up around the throttle plate(do this with the key off). If so, clean it with appropriate cleaner, and have a qualified shop preform an induction service at your next oil change.
Old Dec 5, 2013 | 07:04 PM
acamato's Avatar
Try cleaning the throttle body. The idle on my sisters LR3 used to vary by a few hundred RPM's until I cleaned the throttle body.
Here is a video:
I cleaned it in place (didn't remove it)
Old Dec 5, 2013 | 09:43 PM
Hey thank you for the input. I'll start with the throttle body this weekend and if that doesn't cure it, probably start looking the the injectors.
I figured it was something fuel related. Thank you once again.
Old Dec 10, 2013 | 04:25 AM
bruce741's Avatar
Land Rover 4.4
Jun 12, 2011 07:45 PM
toad2
Apr 12, 2010 07:01 PM
LxR
Oct 24, 2007 04:01 PM
icoolyou
May 16, 2007 05:50 PM
rovergirl79
Aug 4, 2005 02:19 PM
