2005 LR3 compressor not running
Old Aug 4, 2024 | 11:54 AM
biomedguy's Avatar
Default 2005 LR3 compressor not running
Bought this LR3 a few months ago.....air suspension was not working. Bought and installed new Hitachi compressor(same as unit taken off). Bought a Icarsoft LR v3.0 scanner. all codes cleared/resolved while was awaiting compressor and scanner. So far, i've jumpered across relay, to verify compressor works....checked relay for solenoid activation and resistance (good), checked all fuses in hood bay and interior glove box (good)....did the steering wheel alignment , full clockwise and counter clockwise rotation (no change). When starting vehicle, suspension fault light is lit, all terrains lights/dial in center console are off, and display says "suspension fault" and "special programs off". Compressor never comes on at all....what am I missing.....help please!!
Old Aug 4, 2024 | 01:03 PM
DakotaTravler's Avatar
Need codes - with descriptions. EAS is tied to other systems, so if it is not working that does not necessarily mean there is an issue with EAS, it could be another issue which is causing other systems to disable. But the codes will help, especially those specific to the EAS since we want to start there.
Old Aug 4, 2024 | 08:16 PM
loanrangie's Avatar
You must have a hard fault or battery voltage is low, read the codes and see what persists.
RaiderRow
Dec 20, 2021 09:30 PM
rutunifi
Oct 30, 2020 01:53 AM
Brosnan
Aug 30, 2019 09:20 PM
Nicepackage
Mar 5, 2019 05:00 PM
Burfyworld
Apr 1, 2014 10:23 AM
