2006 Ignition Coil Bolt Issues
Old Jun 19, 2022 | 11:36 AM
rsdawson84's Avatar
Default 2006 Ignition Coil Bolt Issues
Hey all. First time doing spark plugs on my own. Ran into an issue trying to remove one of my ignition coil bolts. Either way I turn the damn thing it just spins. Please let me know what suggestions you may have to help me get this damn thing out. Thanks In advance for any help.
Old Jun 19, 2022 | 01:39 PM
SeattleDriver's Avatar
Looks frustrating. Based on the replies in another thread, these attach to nutserts in the intake manifold. The nutsert is spinning in its hole and you need to get it to bite. Either apply pressure downward on the head while you unscrew the fastener, or if that doesn’t work, try to pry up on the hex head flange while unscrewing (insert something between coil and flange). Hopefully one direction will bite and you can get it out.
Old Jun 19, 2022 | 03:52 PM
DakotaTravler's Avatar
What ^ said. You can always drill it after every so slightly and re-secure the insert with high temp JB weld.
Salgriffin
Nov 5, 2021 02:27 PM
mtaylo32
Jun 12, 2019 03:40 PM
jaguarangerover
Sep 4, 2012 11:47 AM
ainiguez
Oct 3, 2009 12:33 AM
sealsupra6
Dec 19, 2008 08:50 PM
