2006 LR3 4.4 coolant leak 149k
Old Dec 19, 2018 | 10:29 AM
jbullock78's Avatar
Default 2006 LR3 4.4 coolant leak 149k
hello all!
i had a small coolant leak on my LR3 with intermittent temp gauge spike. After a min or two it would return to normal. Just this morning after driving on the highway, it spiked and did not return. There is still coolant in the over flow tank but there was coolant splashed on the front of the grill and front bumper. There was no sound of a popping or gurgling. Th Radiator was replaced 1 yr ago.
Any thoughts on leak? I was thinking hoses and or seals.
any input would be great
thanks!
Old Dec 19, 2018 | 11:39 AM
Blackngold77's Avatar
Originally Posted by jbullock78
hello all!
thanks!
with the coolant ending up outside the front, I'd start with all the hoses to/from the radiator, the bleeder screw on top, and the radiator itself.
Old Dec 19, 2018 | 12:43 PM
delormea397's Avatar
I had a coolant leak situation that was from a cracked thermostat housing. My understanding is these tend to crack on the LR3. May be worth a check to see if the housing has some seepage. However, if like you said it's on the outside of the vehicle I would agree with the above poster mentioning the radiator itself. Was it a new ,factory radiator you replaced with?
Old Dec 19, 2018 | 01:13 PM
jbullock78's Avatar
It was replaced by the previous owner so I am not sure. Belts were replaced as well
Old Dec 19, 2018 | 04:05 PM
DakotaTravler's Avatar
You simply need to locate the leak, thats all there is to it. Should not be hard to do but you must get the coolant level up or you can damage the engine. To me it almost sounds like a hose blew off. Do a visual look for anything obvious, then get the coolant topped off (USE THE CORRECT COMPATIBLE COOLANT) and get it up to operating temp to locate the leak. It might even be obvious when you are filling it up.
Stilix
Jun 19, 2019 10:37 AM
Sunflower
Nov 10, 2018 02:05 PM
ZMonet
Jun 24, 2016 04:00 PM
Flyin2jz
Engine & Internal
19
May 4, 2012 08:07 PM
bigugly82
Feb 22, 2008 08:17 AM
