2006 LR3 Clock, TPMS, & Front Parking Aid
Old May 25, 2021 | 11:56 PM
flyer08's Avatar
Default 2006 LR3 Clock, TPMS, & Front Parking Aid
Have GAP Tool,
1. Did have clock available on main nav screen, Flashed as per instructions now small 24hr clock on driver dash, How to get large clock back to nav screen? Both would be great
2. Trying to get TPMS to be active. Can get the icon to show with GAP but not active. Pretty sure its has the function, metal How to make active?
3. Trying to get front Parking Aid Sensors to function in front; rear works fine. Used GAP tool and had them working for short time, a few days, then nothing, Rear still is fine
4. Tried to get the 3 flasher function to no avail
Have gone through GAP PDF a few times and I am sure some me but also not the best instructions I have seen. Have done a few good things with GAP Tool, but would like to fine tune some
Also should add I updated Nav to the 2016+- version.... maybe that took the clock option away from nav screen
Any info helpful
Old May 30, 2021 | 04:10 PM
DakotaTravler's Avatar
1 - Northerlies sure, I dont recall the Nav screen ever having a clock. But I have an LR4 nav unit now so can not check.
2 - Its done in CFF editing.
3 - Again, CFF. Odd they would have been turned off in the first place. Possible hardware issue instead. You can test then with the tool.
4 - Need to update body control first, then edit in CFF to activate.
LONERANGER7010
Dec 29, 2019 10:32 AM
Chris Erke
Nov 10, 2019 12:03 PM
Philip Chan
Jun 21, 2019 11:23 PM
Niver39
Dec 9, 2016 11:17 AM
