2006 LR3 HDC, Air ride, EPB on
Old Oct 15, 2018 | 11:14 AM
LRD2rangel's Avatar
Default 2006 LR3 HDC, Air ride, EPB on
I purchased a LR3
multiple light on
I have disconnected the battery for a full day, reconnected it and still getting multiple lights again
i hooked up my code reader
got :
Engine management
P0056- heated o2 heater control circuit bank 2 sensor 2
Transmission- manual/transaxle and clutch
P186D- Clutch Actuator stuck
Anti-lock brakes
u0403- invalid data received from transfer case control module
Ride level control module
U0416- invalid data received from vehicle dynamics control module
All terrain control module
U0416-invalid data received from vehicle dynamics control module
U0403- invalid data received from transfer case control module
U0421- invalid data received from ride level control module
Body Control Module
B1B02- low freq coil
B1C57- passive start ignition relay coil circuit
B1D14- interior lamps 2 circuit
I have replaced the Brahe switch under the dash, new OE bulbs in the taillights
it has been to a LR dealership for the:
they replaced the transfer case indicator sensor high/low part number IAB500191
removed and replaced gear shift position sensor
they recommended replacing the transfer case control module also.
I am looking for some help in which direction to go at this time.
Old Oct 15, 2018 | 11:27 AM
abran's Avatar
Clutch actuator sounds more like the locking motor on a locking diff. Do you have the rear locking diff?
Old Oct 15, 2018 | 11:29 AM
LRD2rangel's Avatar
that was my orginal reason for taking to the dealership, but this model does not have the rear locking diff.
Old Oct 15, 2018 | 11:33 AM
abran's Avatar
Remove your transfer case module and look for corrosion on the pins. First module behind the battery.
Old Oct 15, 2018 | 11:34 AM
LRD2rangel's Avatar
I removed the battery, removed the transfer case module from the engine bay
i inspected the pins, they look clean with no corrosion. i also opened the module up and inspected the circuit board on the inside. that is also looking good with no corrosion either.
I reconnected the battery and cleared codes.
no luck on getting that cleared, HDC light is still on.
would worn brakes affect that also? HDC, EPB?
Atticus_6147
Jun 5, 2019 03:24 PM
16LR4
LR4
Mar 22, 2019 11:10 AM
bluetick
Jan 6, 2019 08:31 PM
Deaton1076
Sep 9, 2013 10:53 PM
