2006 Lr3 Height Sensor Voltage Question
Old Feb 3, 2019 | 04:04 AM
Mrbuttchin's Avatar
Default 2006 Lr3 Height Sensor Voltage Question
Front Left Height Sensor Voltage
Front Right Height Sensor Voltage
REAR L & R Height Sensor
Old Feb 4, 2019 | 05:36 PM
DakotaTravler's Avatar
What is the question?
Old Feb 4, 2019 | 05:38 PM
Mrbuttchin's Avatar
Sorry about that it was my 1st post in something was to happen because I did post the question lol.
The question is the front left and right sensors are reading considerable lower voltage then the back sensor's as shown in the pictures. Does that just mean I have to replace the sensor's on the front? Or could that mean there something else wrong with it there is not given it complete voltage as the back ones are receiving. Sorry this message was sent with voice to text and I'm horrible at grammar....bahahaha...
Old Feb 4, 2019 | 05:59 PM
Well what is the actual issue with the vehicle? The sensors are variable potentiometers (or something like that). Voltage is applied and the output varies based on height. The voltage reading dictates the hight based on configured values when calibrated. If a vehicles is calibrated perfectly, odds are the sensors will still ready differently. The voltage is converted to an arbitrary value. Thus when calibrating, even those numbers will not be the same. Sensors are for specific locations, so I would not be surprised if the rears have a different voltage too relative to the fronts. In the end, the voltage reading is meaningless unless you use it to find an actual sensor fault.
Old Feb 4, 2019 | 06:21 PM
Mrbuttchin's Avatar
Ok, great. I think I will retest using my gap IID TOOL, purchased via www.gap-diagnostics.com.
I was having problems with the front valve block & leaking shock thst I replaced.
thanks Dakota Traveler
GBR.R
Range Rover L322 (3rd Gen)
Mar 14, 2019 03:52 PM
jbullock78
Aug 20, 2018 10:47 PM
houm_wa
Mar 31, 2016 12:57 AM
arkst1
Sep 11, 2009 01:15 PM
