2006 LR3 Sunroof problem...
Old Sep 13, 2014 | 02:24 PM
Corstrat's Avatar
Default 2006 LR3 Sunroof problem...
My sunroof became stuck in a partially open position. Took it out and saw that the Left Side rail (or arm) that connects to the Sunroof Frame assembly had the plastic nub (that slides into the track) at the forward end of the metal and plastic arm broken. The "rail" is attached to the sunroof frame with four torx screws.
Anyone know if that "rail or arm" can be purchased separately or does a whole new frame assembly has to be bought. There is a number embedded in the side of the part; 10005136B with the letter L below the number, but I could not find this number referencing any part on the net.
TIA
Old Dec 21, 2020 | 08:51 PM
azlandy1's Avatar
Default I have the Same problem. Any luck sourcing the part?
tia -
did you have my luck ?
TIA
Tia did you have any luck finding the part ?
Brosnan
Jan 3, 2023 04:10 PM
azlandy1
Sep 20, 2020 01:27 PM
jrkstore43
Sep 17, 2012 11:32 PM
BigRed98
Jun 21, 2010 12:30 AM
And4848
Dec 10, 2008 02:40 PM
