2006 LR3 - Transmission fault, HDC fault, Parking brake fault, Engine system fault
A few weeks ago I started getting the following: transmission fault, HDC fault, Parking brake fault, Engine system fault accompanied by every light on the dash flashing including my hazards. I can restart it and everything will clear except the engine system fault. If I disconnect the battery everything will clear, however, it only takes a few miles for it to happen again. I took it to the dealership and they said there were several fault codes that they blamed on a bad battery and a couple bad sensors. They replaced the battery and sensors and it was fine...for a day. Now it is worse. Before I could place it in neutral while i was driving and restart it to clear the faults, now i have to put it in park and even then it takes a while to start. I removed the drivers side and passenger side kick panels and door sill plates and inspected for corroded wires. I didnt find anything. I have read where other people have had similar problems but what resolved their issues has not helped me. Does anyone know of anything else that could be causing this problem? My interior is not put back together so i can check different things fairly easily. Any help would be greatly appreciated.
It is you cluster you need a new cluster and reprogram it.
abrahamd
May 7, 2023 05:32 PM
06Range
May 8, 2013 09:01 PM
