2007 Land Rover lr3 ( suspension problem)
Old 03-22-2018 | 10:01 PM
Fahadazim's Avatar
7th Gear
Default 2007 Land Rover lr3 ( suspension problem)
Hi all, I need some help with my lr3, suspension, I have already changed air ride compressor, and also cleaned rear block valve,
suspention light comes on when it try to release pressure
Old 03-22-2018 | 11:07 PM
abran's Avatar
What’s the exact codes? What compressor did you install, new or rebuilt?
Old 03-22-2018 | 11:09 PM
Fahadazim's Avatar
7th Gear
it’s a brand new compressor,
code : pressure does not decrease when venting gallery
Old 03-23-2018 | 07:34 AM
abran's Avatar
Exhaust valve on compressor is bad.
What brand? Return it
Old 03-23-2018 | 08:04 AM
Fahadazim's Avatar
7th Gear
If I leave my drive’s door open and start the car, then compressor turns on, I let it run until it fill up the reservoir, then I close the door and rais the vehicle to off-road position then I bring it back to standard height And it comes to normal height with no problem, but when u drive after 10 some time 20 kms it come back or if I shut off the car few time let it sit for more then half hour light will come back,
i also notic if we drive 2 or 3 days with light on, without filling up the reservoir , front of the vehicle goes down but rear stays up
Old 03-23-2018 | 08:23 AM
abran's Avatar
So you have a leak at the front and your new compressor is defective.
What brand is the compressor?
Old 03-23-2018 | 08:25 AM
Fahadazim's Avatar
7th Gear
I don’t remember the brand but I will check it
Old 03-23-2018 | 11:43 AM
houm_wa's Avatar
There was a recent software upgrade...can cause faults like this. If it's an AMK compressor, you might want to get that software patch.
Old 03-23-2018 | 02:40 PM
Fahadazim's Avatar
7th Gear
I found out it’s a hitachi
Old 03-23-2018 | 03:07 PM
abran's Avatar
I would return under warranty.
Quick Reply: 2007 Land Rover lr3 ( suspension problem)
