2008 LR3 Keyless Entry Not Working
Hello
Got an 08 HSE with the keyless entry not working at all. Stopped, then worked once, then no more (both key fobs). Lights were flashing several times at unlock before it stopped working. There is the common water leaking into the passenger door sill. Looked, but no splice could be found on passengers side. No water leak on drivers side. Checked power at the receiver. It has power, and looks like it is sending a signal out when key fob buttons are pressed.
Any thoughts? Does someone know the routing of signal wires to lock/unlock doors.
Fixed
Just thought I would give an update. The blue signal wire from CJB to receiver had somehow been severed or worn. Spliced in a new wire to the receiver and problem solved.
I'm probably one of two people this has ever happened to, but something to check if you cannot solve your keyless entry not working.
JEbmwRX1
11-13-2015 07:57 PM
