2008 with rough idle until pace into gear
Clean your throttle body. That will fix the idle fluctuation, the blade controls idle speed, no IAC, and when it gums up with Carbon, you create an air dam, so it will constantly be adjusting itself due to it's known position not allowing enough air in. Keep in mind though, that there will be just as much build up, actually more, throughout the entire intake system, and the proper repair is a full induction service to clean it all out. Also a good time ti check the PCV for proper functionality.
flavorking
02-10-2008 12:33 PM
