275/65/18 rubbing solutions? Modifications?
Old Apr 23, 2009 | 04:00 PM
roveribis's Avatar
8th Gear
Default 275/65/18 rubbing solutions? Modifications?
This tire is just over 32" tall and I was expecting rubbing.
Has anyone done any modifications to alliviate this?
I have searched the forum, but can't find anything on this.
Thanks
Old Apr 23, 2009 | 05:41 PM
drzjoint's Avatar
do you have rubbing? If so in what modes and while doing what?
You may want to modify the height sensor rods. I can make you a set you will gain 2" of height in all modes.
Old May 5, 2009 | 10:40 AM
roveribis's Avatar
8th Gear
Default rod modification
Well I have another set of wheels with 30.5" tires. These are for everyday use.
How difficult is changing the rods everytime I go offroad? I looked at the mechanism and it seems fleemsy... I would break the sensor arm...
What is your experience?
Old May 5, 2009 | 11:50 AM
drzjoint's Avatar
It looks flimsy but I have swapped them about a dozen times and have not had any issues.
Old May 12, 2009 | 02:30 PM
05LR3AZ's Avatar
So you just switch them (install then uninstall) when you don't need the extra height? Is this like a 1-2hour thing for the avg joe? I have rubbing on mine but just barely and I'd like that extra height while off road...
Old May 13, 2009 | 09:33 PM
jimbiram's Avatar
Geez, just get a set of Cooper Zeon LTZ's from Discount Tire. They run long, quiet, and they fit. The amount of rubbing is so insignificant, as it only occurs on deep decompression. I have over 30,000 miles on mine and there are many more miles left. It really is a simple decision. Anything bigger than that is not worth the time unless you invest in a lift kit and a commercial kit is not yet on the market, although I know of one coming out soon.
Old May 14, 2009 | 08:38 AM
drzjoint's Avatar
You can swap the arms out in about a half hour I can do it in about 15 mins. It is simple and works great.
The lift that is comming out is basicly modified sensor arms. Why wait I have been making and using them for over a year.
Chris-bob
Dec 18, 2020 01:12 PM
Gasha
Mar 9, 2016 02:44 PM
awer25
May 3, 2010 12:41 PM
Malafax_Dand
Apr 3, 2008 04:24 PM
