After 206k Miles Change Water Pump as a Precaution ?
Old Sep 24, 2022 | 01:42 PM
Athana's Avatar
Default After 206k Miles Change Water Pump as a Precaution ?
Hi. Thank you as always for helping us keep LR3 going.
I was thinking if I should change Water Pump as a precaution now
at 206,000 Miles ? We know a guy with around this much milage with similar Range Rover Sport
who's Water Pump has just failed.
I don't want any chance of it going and blowing our engine,.
My main question is while in there what else should be changed as a good idea.
Many thanks
Old Sep 24, 2022 | 01:47 PM
elemental_garage's Avatar
I'm about to do my cooling system at about 154k miles. Not because it needs it, but because it's more convenient for me to go through it at a time and place of my choosing rather than being forced to. It's really hard to predict when things will fail without more data points. At 200k miles it's not a terrible idea. While you're in there you might do belts and hoses too, and the thermostat/housing since it's plastic.
Old Sep 24, 2022 | 02:18 PM
NJOverland's Avatar
Many thanks
Won't hurt. I would get a scangauge or something like that so you can keep an eye on temps real time and not go off of a gauge. This way if the pump does fail, you won't be too late to catch it. I watch trans and engine temps closer than I watch my speed.
Old Sep 24, 2022 | 07:49 PM
Blackngold77's Avatar
Seems like a good preventative decision to me.
Just make sure you get a replacement that comes with the metal gasket and not the paper one. The paper gasket is all but guaranteed to leak like a sieve within a year
Old Sep 25, 2022 | 03:05 PM
tracyc's Avatar
I'm a fan of the 1 piece AC Delco water pump myself.
Old Sep 26, 2022 | 09:54 PM
DakotaTravler's Avatar
The pump is easy to replace. I would certainly do it. In fact, I STILL have to do mine. AC Delco pump ready to go in. But I will also be performing a full cooling system flush with citric acid. And I will be installing a block heater.
Old Sep 28, 2022 | 07:03 PM
Athana's Avatar
I ordered the Atlantic British AirTex Water Pump and two belts.
In the past Abran wrote that some sort of grey stuff should be put around metal gasket ?
Old Sep 28, 2022 | 07:28 PM
AirTex has a high failure rate. With that said, they seem to make two versions. I believe Aritex was OEM and the OEM pump is relatively expensive. Then they seem to have an economy one which is very prone to failures. I never put stuff on a water pump gasket. Makes replacement less fun since you have to clean the surface that much better.
Old Sep 29, 2022 | 08:07 AM
Athana's Avatar
Ok..thanks.
The original one in the car has been going for 206k miles.
I hope the OEM one I got from Atlantic British is the same unit..it was only $119 or so.
There's a better one ?
Old Sep 29, 2022 | 10:42 AM
I believe the one by Atlantic British is the OEM and not the economy one found on places like RockAuto and Amazon. That one is about $36 bucks. Either that or Atlantic is putting a 4x markup on the economy version. But they do list it as the OEM pump.
