After 206k Miles Change Water Pump as a Precaution ?
Old Sep 29, 2022 | 10:55 PM
DakotaTravler's Avatar
Yeah, I would think AB would not sell the lesser version. Can always call em! I am certain they know the product well.
Old Sep 30, 2022 | 12:16 AM
Blackngold77's Avatar
Originally Posted by Athana
Ok..thanks.
The original one in the car has been going for 206k miles.
I hope the OEM one I got from Atlantic British is the same unit..it was only $119 or so.
There's a better one ?
The Delco one is only $60 on Amazon and Partsgeek.
Part is 252-800
Old Sep 30, 2022 | 08:24 AM
AtlanticBritish's Avatar
LR Forum Vendor
Originally Posted by elemental_garage
I believe the one by Atlantic British is the OEM and not the economy one found on places like RockAuto and Amazon. That one is about $36 bucks. Either that or Atlantic is putting a 4x markup on the economy version. But they do list it as the OEM pump.
Yes, the $119 one we sell is definitely Airtex OEM version under part # 4575902OEMA.
__________________
Old Oct 2, 2022 | 07:20 PM
Good to know. Maybe I will keep my Delco as a backup and get the OEM AirTex. The price is right.
Old Oct 3, 2022 | 09:37 AM
Athana's Avatar
Hi..Just the metal gasket that comes with it yes..
The metal gasket is actually not flat, it seals effectively on its own, or does some other stuff need to be used as well.
I'm going to order the pulleys to do
Water Pump,Belts and Pulleys.
How many hours for a mechanic do you think.
Have to do heater core next : (
Old Oct 8, 2022 | 03:01 AM
448Globetrotter's Avatar
3rd Gear
Unhappy
I have just purchased a new water pump for my LR3 4.0 litre V6 petrol engine. It comes with a metal gasket and the instruction say's to add a gasket cement to it when fitting.
Old Oct 8, 2022 | 09:05 AM
Athana's Avatar
Ours is the 4.4 V8.. no instructions in the one we got but box had been opened. I called Atlantic British and was told install only the metal gasket, it collapses to seal the joint. God bless that this Water Pump lasts as long as the original (207k miles excellent quality) : )
Old Oct 8, 2022 | 02:05 PM
No sealant should be needed, per factory manual on all three engine types. 4.4 instructions attached here....
File Type: pdf
Old Oct 9, 2022 | 12:38 PM
Athana's Avatar
Thank you so much
Old Dec 28, 2024 | 01:10 PM
Athana's Avatar
Default Atlantic British Airtex Water Pump No Good
Well the new Airtex OEM Water Pump from Atlantic British Cracked after only 21,000 miles (two years)
What a piece of junk. The original lasted 207,000 miles it failed at 228,000 and I changed it not because of failure but pre emptively. Atlantic British should find a better product out there cause some of us buy 80% of our stuff from them relying on getting good stuff.
Mechanic said he is going to get us a better one than this " OEM" one. I read that the original was Airtex but made in Spain with a brass propeller but no longer available. Anyway I need this damn car and this rubbish started on Christmas Eve mechanic thinking leak coming from hose connections..now it's back with the real cause and still no car when I need it.
