Air bag light on.
Old May 27, 2015 | 07:35 PM
Disco3JR's Avatar
Default Air bag light on.
I'm hoping someone can shed some light on the location of the passenger side front impact sensor? It threw the code B0098 which is right side restraint impact sensor 3 my scanner says? I'm having trouble tracking down its location inside the Truck.
Thanks in advance for the help!
Old May 28, 2015 | 05:16 AM
Alphamale's Avatar
Hope this helps,
1 - Door side impact sensor
2 - B pillar side impact sensor
3 - Rear quarter side impact sensor
4 - Third row side air curtain
5 - First and second row side air curtain
6 - Safety belt pretensioner and buckle switch
7 - Seat position sensor
8 - Occupant classification module (NAS only)
9 - Seat cushion pressure sensor (NAS only)
10 - Seat cushion pressure pad (NAS only)
(Read in conjunction with Thumbnail 1)
IMPACT SENSORS
(Thumbnail 2)
Impact sensors are installed in the front and both sides of the vehicle. The use of multiple impact sensors provides shorter air bag trigger times, through faster detection of lateral and longitudinal acceleration, and improves detection accuracy. There are two front impact sensors attached to brackets on the body front support frame, just above each front longitudinal.
There are six side impact sensors located in the passenger compartment, as follows:
􀁺 One attached to each front door.
􀁺 One attached to the base of each B pillar.
􀁺 One installed in each rear quarter, above the rear wheel arch.
Each impact sensor incorporates an accelerometer and a microcontroller powered by a feed from the RCM (restraints control module) . The power feed also provides the interface connection through which the impact sensor communicates with the RCM (restraints control module) using serial data messages. Acceleration is evaluated by the microcontroller and transmitted to the RCM (restraints control module) , which then makes the decision on whether or not to activate the air bags and pretensioners.
Attached Thumbnails Air bag light on.-secondary-restraint.jpg   Air bag light on.-sensor.jpg
Old May 28, 2015 | 05:54 AM
Disco3JR's Avatar
Wow that's exactly what I was looking for���������������������� thank you! Is it safe to say that #3 sensor is the rear quarter side impact sensor?..
Thanks!
Old May 28, 2015 | 06:57 AM
Alphamale's Avatar
Yes, as far as I can make out it's located behind the 'C' pillar lower trim. If you need to fit any new ones they have to be paired to the car by reading the new bar code.
Old May 28, 2015 | 08:21 AM
Disco3JR's Avatar
That is great, thank you. I suppose I need a dealer to put that new serial number into the computer? Or is there a way to do it with my scanner?
Old May 28, 2015 | 01:35 PM
Alphamale's Avatar
Can't help you there I'm afraid, but hopefully someone reading this will have an answer.
jjadams
Jan 8, 2012 10:52 AM
catchthebig1
Sep 24, 2010 11:57 AM
akamoore
Jan 16, 2010 08:12 AM
MikeLi
Sep 15, 2008 02:24 PM
scobie
Oct 19, 2005 12:42 AM
