Air compressor
Old Jun 22, 2021 | 02:30 PM
Avs2021's Avatar
3rd Gear
Default Air compressor
Hi Everyone
I need an opinion about the air compressor for the air suspension system. I am just curious. The compressor activates every 24 secs interval and runs around 5 secs and the the vehicle is on park. Is this normal?
Appreciate any help
Old Jun 22, 2021 | 04:08 PM
douglastic's Avatar
Sounds like a leak
How much does it drop when sitting overnight?
Old Jun 22, 2021 | 05:41 PM
COSPILOT's Avatar
Shockingly my struts are original and still fine with 163K on it. My valve blocks, the tank, and the compressor needed to be replaced a few years ago. The tank had some very tiny pinhole leaks that caused the compressor to work overtime. I never did find any leaks beyond the tank, but I’m convinced I was wise to do everything at the same time.
Old Jun 27, 2021 | 09:57 AM
Rufflyer's Avatar
Sounds like you are ready to once again, put it into off road height and get out the spray bottle of soapy water. I would starting where douglastic suggested. Raise to off road height, pull fuse #26 (in the fuse box under the hood) and see what happens after 12 -24 hours. As a side note you should measure from the center of the wheel to the wheel arch before you pull the fuse and again after the waiting period so you have an idea how far it drops.
hope this helps
Jeff
Old Jul 2, 2021 | 12:05 PM
Avs2021's Avatar
3rd Gear
Hi thanks for reply I appreciate. Yes it did drop to its lowest level but only the front suspension even i took off the fuse.
Old Jul 2, 2021 | 12:11 PM
Avs2021's Avatar
3rd Gear
Hi thanks for response I appreciate your help. I response to douglastic. I will try as what you recommend and give you response as soon as possible.
cheers
jtherien53
Apr 30, 2021 08:26 AM
usserya
Sep 7, 2020 06:03 PM
05TurboS2K
Aug 7, 2019 07:47 PM
GCS1
Feb 17, 2008 07:30 PM
DiscoDave
May 3, 2007 07:01 PM
