Air Compressor Dryer Desiccant
Old Jul 5, 2022 | 09:17 AM
lenzda's Avatar
Default Air Compressor Dryer Desiccant
I'm going to do some basic service on my air suspension system including new seals on valve blocks and replace desiccant in compressor drier. Any recommendations on what type of desiccant to use?
Old Jul 5, 2022 | 10:44 AM
douglastic's Avatar
I just bought a jug of blue beads from amazon
Old Jul 5, 2022 | 11:02 AM
lenzda's Avatar
have you had any issues with it?
Old Jul 5, 2022 | 12:48 PM
douglastic's Avatar
no issues for . . . dang, 50k miles
I am prob overdue for a refresh
Old Jul 5, 2022 | 06:30 PM
DakotaTravler's Avatar
Ditto on Amazon. This is what I bought, but there are lots of options. I will be chaining mine soon, try to do it every year just to be super active and its so easy/cheap to do.
Amazon Amazon
Old Jul 6, 2022 | 07:40 AM
lenzda's Avatar
Thanks for the recommendations, wasn’t sure if there was a specific type of desiccant required by LR
Old Jul 6, 2022 | 05:00 PM
They probably have something and desiccants can vary... but any basic one will work just fine. The key is changing it regularly.
Old Jul 15, 2022 | 08:38 PM
lenzda's Avatar
Just changed my desiccant. I’ve attached the photos of the old (beige) and new (blue). As you can tell they are quite different. I did a little research and the original desiccant appears to be molecular seive desiccant. The new is silica gel desiccant. the basic difference is the molecular seive is much more absorbent. I suspect the silica gel will require
Molecular seive desiccant
Silica gel desiccant
more frequent changes.
fyi my compressor and drier are of the AMK variety. Original to the 2008 vehicle as far as I can tell.
Old Nov 27, 2024 | 12:09 AM
archaeology_student's Avatar
Did anyone change the original o-rings as well as the little white filters?
if so, what size are the O-rings?
Thank you!
Old Dec 3, 2024 | 11:25 AM
douglastic's Avatar
Search X8R LR3 on e bay
they have kits - I also got their aluminum dryer cap to fix my cracked OEM one
zacharyz28
Dec 29, 2021 09:46 PM
Avs2021
Jul 2, 2021 12:11 PM
usserya
Sep 7, 2020 06:03 PM
05TurboS2K
Aug 7, 2019 07:47 PM
DiscoDave
May 3, 2007 07:01 PM
