Air spring air supply-Alorithm based failure
Old Sep 2, 2016 | 09:25 AM
Rufflyer's Avatar
Default Air spring air supply-Alorithm based failure
Having no hurricanes in Houston for more than 8 years a trip to the inlaws seemed a good eecuse to load up the land rover in bug out mode and give it a good trial run. So. I headed north witwit a full tank of gas and the four jerry cans. They got me from Houston TX to Big Cabin OK. Seem good. Fully loaded it made 16.4 mpg on the dash. Not bad.
Problem is about every hour I got the suspesion light on the dash. Shutting down at the rest stop would make the light go away. (for an hour or so)
IiDTool said:
Suspension
• C1130-66 (6C) Air spring air supply - Algorithm based failure - signal has too many transitions/events
( on 01-09-2016 10:29:16 at 162877 mi )
I cannot find this code in a search here or the other forum. Also seems my car does not know what day or time it is since I removed the sat nav.
Could I have a bad air bag? It only seems to be a problem after about 1 hour while loaded down with people dogs and gear.
AKM compressor about a year ago.
Old Sep 2, 2016 | 11:08 AM
KMET's Avatar
Have a read here.
DISCO3.CO.UK - View topic - Suspension problems & codes. :-(
Old Sep 3, 2016 | 12:57 PM
Rufflyer's Avatar
Default Missed that search
Thanks for the link. It helped. Got the thing to solid pavment, raised to off road heighf, pulled fuse #3. Recorded the following before shutting off car after the compressor stopped:
LF 50
LR 46
RF 51
RR 54
Gally pressure 1720 Kpa
Motor temp 52 f
Pump temp 116 f
Now I wait.
Old Sep 3, 2016 | 05:56 PM
Rufflyer's Avatar
Default Update
LF 14
LR 20
RF -26
Rr 0
Did I pull the wrong fuse? Or is there a leak that affects all four wheels?
Also, if I monitor the compressor temp while driving, what would be the max temp I should allow before pulling over and letting it cool down (assuming it is coming on too often)
Old Sep 11, 2016 | 10:52 AM
Rufflyer's Avatar
Default Update
750 mile drive home no light, no issues. 15 mile commute on Tuesday light came on, same code.
Replaced front control valve (white powder seen in plactidirection.on Tuesday night.
Soaked valve and right front strut with soapy water. Found and HEARD leak on the lower portion of the right front strut.
Ordered 2 Arnott struts.
While waiting, I will pull the cover on the compressor and see if the drier cap is cracked.
Not fixed yet, but at least it is a start.
Thanks for pointing me in the right direction.
icyhot201
Nov 27, 2012 12:32 AM
RjBu
Oct 14, 2009 10:31 PM
ajh
Jan 8, 2008 09:57 PM
freedomintheskies
Oct 1, 2006 08:57 PM
Bryan
Off Topic
Nov 11, 2004 06:36 PM
