Air Suspension fault or not?
Yeah, I have an iPhone, but I really thinkin about rods, cause I don't need high tech, expensive additional parts. Okay, I know you suggest the IID tool cause it is comfortable and better for off roading,(you can switch the heights every time when you need) but you know, I am always use my car on trail, go to the farm then go back to the city, and to the farm again... every day. So thats why I thinkin about rods, always on 2,5" in normal mode.
BUT I don't know just that: if the air compressor working a lot, will it die? Is it right, when I set the new rods, in normal mode the car will be on 2,5"... so the suspension need more air to hold that height, -» compressor will work more than before.
is it right?
SORRY for my english.
is it right?
I've been running rods for about 30,000 miles and everything is fine, make sure to get an alignment if you do get the rods. Yes normal height is now your offroad height, and offroad height is now extended. I run rock armor adjustable rods, I ran them at 1.5" now I run them at the full 2.5".
LR3 / LR4 Parts/Accessories
kbarker27
Oct 13, 2023 04:03 PM
Arth111
Feb 26, 2022 06:28 AM
06Range
May 8, 2013 09:01 PM
