Air Suspension height and Leveling
Old Apr 29, 2018 | 10:35 AM
DakotaTravler's Avatar
If those are your measurements, you are not on a level surface. Or the frame is twisted, body panels off, etc. Or possibly some folding of space cause by a local wormhole. But it seems your front is dropping. That can be one or both front struts leaking or the valve block up front. My front was dropping a good amount overnight. I rebuilt the valve block ($35 ebay kit for all three blocks) and it solved the issue. But now it leaks down again a little. I think in my case, the white old desiccant from the compressor drier worked into the block again and I need to clean it. I did just rebuild the compressor too, so that will take care of the desiccant issue going forward, less what powder is in the lines for a while.
04in719
Oct 27, 2017 05:06 PM
Luckyjayb
Feb 22, 2017 05:08 AM
Greatpyr
Jun 19, 2013 05:22 PM
PabloM
Sep 17, 2012 02:45 PM
bhorwhat
Sep 9, 2009 06:41 AM
