LR3 SE 2006 making clicking sounds when not in use?
Old May 2, 2018 | 09:11 AM
Athana's Avatar
Default LR3 SE 2006 making clicking sounds when not in use?
Hi..
LR3 SE 2006 making clicking sounds when not in use..sometimes I'm in garden and haven't used car since the day before, I hear clicking sounds from under the car..
Any idea or had this experience?
Old May 2, 2018 | 11:25 AM
houm_wa's Avatar
Hmmm...where does your vehicle "live?" Outside or in a garage? Is it possible sone mice call it home? That would explain the noises and maybe your strange electrical (brake switch) issue.
Have you done a thorough search on this forum? I seem to recall someone having the same symptoms in terms of it being fine if brake is pressed but otherwise not.
Old May 2, 2018 | 08:36 PM
Athana's Avatar
Thank you..
The clicking is louder than a mouse would make..it would be a larger animal.
Yes the strange brake issue..with brake light switch bypassed and dangling there..with car on snow gravel setting in normal height runs good but brake lights on all the time so on the way to dealer tommorow morning.
One thing my wife notices is the brake.. since just before issue started all of a sudden it needs to be depressed farther down for car to stop.??
Old May 3, 2018 | 12:35 PM
houm_wa's Avatar
If the brake pedal switch is dangling....then I think I know your problem!
Old May 3, 2018 | 03:10 PM
thorgal's Avatar
Clicking sound could come from electric motor from under the driver's seat.If you Google a clicking sound from under seat+lr3 this topic will come up. I had that problem few years back, but after disconnecting the seat module for the night, the sound never came back. Hope this helps..
Old May 3, 2018 | 03:44 PM
Geo's Avatar
Geo
My Throttle body motor makes noise sometimes after shutting off. It stops if I unplug it. It's under the plastic cover near the front of the engine. Does your noise get louder when you look under the hood?
Another thought, is the ride height settling? Slow leak? Maybe the valves opening to level the truck.
Old May 4, 2018 | 07:14 PM
Athana's Avatar
Clicking long before we disconnected brake light switch which was just a few days ago.
Old May 4, 2018 | 07:15 PM
Athana's Avatar
Will look into that.thanks
djkronik57
Dec 1, 2019 11:28 PM
BS50MGSXR
Dec 20, 2016 05:08 PM
Bean
Jul 15, 2010 11:13 AM
domyo
Sep 25, 2008 12:19 PM
Disco2Guy
Jan 20, 2008 01:16 PM
