air suspension warning light on after the selected height reached
Old Jun 11, 2018 | 12:24 PM
jayoi's Avatar
5th Gear
Unhappy air suspension warning light on after the selected height reached
Hello everyone, its my pleasure to be here and post my issues with air suspension with you and I really appreciate any help and suggestion.
I just bought a 2008 LR3, with 118000 miles on dash.the car runs good, the previous owner just changed the compressor ( yes only the compressor, with dryer too, I guess).
The problem is, every time when I start the car, the compressor will work for a while, around 3-5 mins, with a loud noise, and then once the car reaches its selected height, the compressor with be turned off and then the amber warning light comes on and message " suspension fault" comes out on screen. The car can run and I didn`t feel too much shake so I suppose the air suspension system can hold the car in its proper height but I just have no idea why the amper warning light keeping on for all the time --- until I turn the car off.
related problem is if I drive the car without waiting for the compressor fill the air in the suspension system, then the air will not be filled during car`s running and the warning light will turn to red and " maximum speed 30 mph" will come out which is the worst part of this issue...
Hope I have described the problem clear enough and I appreciate any analysis and discussions..
Old Jun 11, 2018 | 02:13 PM
houm_wa's Avatar
This is interesting because it sounds like two separate issues. The compressor sounds wacky...maybe something went wrong on the install. Maybe an AMK compressor went in but the software (and relay) didn't get updated.
The red "keep it under 30 mph" bit sounds more like a cross-articulation fault but I suppose could still be related to the above.
Old Jun 13, 2018 | 10:51 AM
jayoi's Avatar
5th Gear
Default thanks
an
Just checked the brand of the compressor, it is an AMK and I believe the software didn`t update yet. Will do it in the dealer and hope can resolve this issue. Thanks a lot for your suggestion.
Old Jun 13, 2018 | 01:59 PM
houm_wa's Avatar
You're welcome and I hope that solves it....also don't forget the new relay!
Kevindk9
May 26, 2023 06:11 AM
RaiderRow
Dec 20, 2021 09:30 PM
Applause
Aug 24, 2014 10:38 PM
alti
Oct 25, 2013 10:45 AM
armycamacho
Mar 8, 2012 02:03 PM
