Airbag light
Old Mar 1, 2025 | 06:19 PM
BradBow's Avatar
Default Airbag light
First post for me, just picked up a 2006 LR3 this week and have been starting to work through issues.
Biggest issue I have is the Airbag SRS light is on. I have the Autel AP200 with the LR tools (seems to work okay, was the easiest to get at present). I’m seeing a code for drivers seatbelt pretensioner open. I’ve tested it and compared to the passenger and I have about 2 ohms under the seats for both so I don’t think it’s that. It’s showing 10.2 ohms for the driver’s pretensioner when I look at the live data.
There are lots of posts referring to the clock spring with the SRS light. Does anyone have experience with a similar situation and this being the cause? It just seems odd that this would be causing it.
Old Mar 1, 2025 | 07:29 PM
CantComplain's Avatar
First of all, welcome to the forum and the joy that is Land Rover.
Secondly, people are going to jump in here and say to get the Gap tool. I had the AP200 for a minute and it was actually pretty impressive, especially for the price. I ended up getting a great deal on on the Gap and wanted to mess with something the autel didn't do, I think it was adding a lift but not sure. But it competently read most if not all of the ECU's and it clearly is reading the SRS module.
Thirdly, and related to above: if the ECM has told the display to throw the SRS light, and the ECM tells you (via Autel) that it's the driver's side pretensioner, that is where I'd focus. I personally am not not familiar with that error or device, but if it's swappable with the passenger, I'd do that and see if it moves. If not, I'd get a wiring diagram and trace the wires back to wherever they go, including whatever fuse services it. Wiring is a common fault with these rigs and a break or unintentional ground could conceivably trigger this. Digging around indicates an accident that fired the pretensioner could cause this. Any chance? See https://landroverforums.com/forum/lr...-needed-48740/ and all the attachments.
Anywho, that's how I'd go about it. Stay strong on the AP200! I'm sure others will chime in with helpful advice.
Old Mar 6, 2025 | 07:26 PM
BradBow's Avatar
Default Success!
Thanks for the advice,
Tonight, I finally had some success with this! It seems the connector under the seat was the issue which is interesting because I had looked at it before. If it comes back on I know where to look at least. As you suggested, focusing on that part seems to have been the ticket.
Hopefully it stays off now!
Coldwater
Mar 15, 2023 04:29 PM
gmortie3rd
Jun 7, 2013 03:29 PM
Disco2001
Sep 4, 2011 12:13 AM
NATEDOGG
Oct 14, 2009 03:27 PM
bphiggins
Aug 21, 2006 12:31 PM
