Alarm goes off randomly at night. Help?
Old Aug 25, 2015 | 10:04 PM
allroadinvail's Avatar
5th Gear
Default Alarm goes off randomly at night. Help?
Sorry for not searching. I lock the car and the alarm goes off five minutes later. I get a warning for the bonnet open. I would assume this is why the alarm goes off. I'm pretty sure it's a sensor that isn't working but which one? The hood is shut as well as the rear hatch. Any insight?
Old Aug 25, 2015 | 10:56 PM
bbyer's Avatar
Default Defective bonnet switch on right passenger side
Within the file link below is a 17 page pdf re the locking and alarm system. Note on page 9/17 of the pdf, LR has it explained backwards but the quick fix is to unplug the connector from the switch and ground across the two pins on the harness side.
The proper fix is to purchase a new switch - the problem is common and the fix routine.
Further to my comment re page 9/17, the explanation of the operation of the hood ajar switch being wrong, the bonnet switch operates similar to the door and tailgate ajar switches; that is when a "door" is closed, the switch is closed to maintain a ground back to the CJB. Opening the hood, door, or tailgate removes the ground breaking the circuit and hence allows for an alarm condition. As such connecting across the two conductors on the harness side will fool the system into thinking the hood is shut.
DISCO3.CO.UK Photo Gallery - Power Window and Door Lock Circuits
File Type: doc
File Type: doc
Old Aug 26, 2015 | 07:34 AM
5th Gear
Thanks for the response! I reread my post and I should have mentioned it's an 08 LR3. I'll look into it this afternoon.
Old Aug 26, 2015 | 01:05 PM
nevillusa's Avatar
Ditto what bbyer said - get a new Hood Switch. I did this. Very quick and easy fix. Sorry, can't remember where I got it from.
Old Aug 26, 2015 | 08:11 PM
LR Techniker's Avatar
Super common on L319, L320 and L322 platforms. So common that I keep a hood switch in stock.
Here is an example where a good diagnostic tool is very valuable, because you can look at the alarm history, but the fact that you get the "bonnet open" message is proof enough.
Cheap part and easy to install.
Old Aug 26, 2015 | 09:00 PM
5th Gear
Got the switch and it is fixed! 40 minute drive to the dealer $47 and 10 minutes replacing it. Now the Audi and of course you fix one car the other isn't happy. I guess the Audi is getting some love tomorrow... Yes I am a glutton for punishment. Thanks for the help guys! I also have to say you were pretty nice to me for my second post. Most forums will flame you for not searching before posting.
Old Aug 26, 2015 | 09:39 PM
bbyer's Avatar
Default this forum is friendly
I would say for the most part, this is a pretty friendly forum - actually most of the Land Rover forums are. I think to own a Land Rover, you have to pretty a pretty patient type as they can a times, be trying. I like to think the forums reflect that.
Old Aug 26, 2015 | 10:51 PM
Joemamma1954's Avatar
The members are friendly, the search engine on this forum is not.
Old Sep 4, 2015 | 10:23 PM
Steven Hornbuckle's Avatar
Hello fellow LR lovers. I have a ’06 LR3. I amexperiencing the familiar alarm intermittently going off. It only happens in the summer/spring timeframe went the truck is out of doors in the heat. Initially I replaced the bonnet switch andstill experienced the same problem. Asof late, I replaced the bonnet latch assembly and still having the sameissue. I will say that from time to timeI get a message on the dash that one of the doors is not closed as well as thereare times with I cannot lock the truck (with remote) because one the doorsseems not to be closed and the horn sounds. I would love some feedback from others that have experienced thisproblem. Also, is there a way that thealarm system can be disarmed until I can figure out this problem and have it resolved? I am currently leaving the truckunlocked. Thanks in advanced for yourhelp.
Mountain Goat
Aug 30, 2022 11:08 AM
Tercan
Jun 20, 2017 08:43 PM
spikeRovah
Jul 22, 2014 01:14 PM
marlymarl
Apr 21, 2012 12:49 PM
Princess
Aug 26, 2009 07:22 PM
