Another HDC, ABS, Transmission fault
Old Jun 6, 2021 | 08:14 PM
loanrangie's Avatar
Originally Posted by Kushan Gunawardane
The error came back on yesterday but nothing this morning. I let it sit over night and im getting 12.6V when off and 14.10V when idling. Does the values seem right?
Yes, voltages are what you'd expect.
Old Jun 6, 2021 | 09:09 PM
Kushan Gunawardane's Avatar
Oh ok. Looks like ill be waiting till i can get the codes read on the 15th. Im kinda out of options on what to try till then.
Old Jun 9, 2021 | 10:03 PM
Update -
Bought an iCarsoft code reader and the following codes showed up after deleting old stored codes and turning ignition on few times till Errors popped up on dash.
U0155 - Lost Communication With Instrument Panel Cluster (IPC) Control Module
B1C82 - Headlamp washer relay coil circuit
B1C96 - Alarm LED circuit
B1BA0 - Excessive challenge requests or start attempt in storage mode
U0416 - Invalid data received from vehicle dynamics control module
B1C32 - Steering column tilt solenoid
B1B89 - Seat slide motor speed/position sensor
B1D84 - Headphone Panel 1
P186D - Clutch actuator stuck
B1D14 - Interior lamps 2 circuit
B1B91 - Seat tilt motor speed/position sensor
B1A01 - Speaker 1 Circuit
B1B02 - Low frequency coil
U1A4A - Invalid data received from differential control module - Rear
U0416 - Invalid Data received from vehicle dynamics control module
B1D13 - Interior lamps 1 Circuit
B1C34 - Steering column telescope solenoid
U0403 - Invalid data received from transfer case control module.
B1C26 - Pedal motor feedback circuit
U0102 - Lost Communication with Transfer Case Control Module
I have the Rear locker and i know my rear driveshaft is bad which i will be replacing this weekend - Not sure if its related.
If anyone has any leads on which these codes i should look for that would be greatly appreciated.
Thanks
Old Aug 16, 2021 | 01:44 PM
Structural1's Avatar
Hi... did you get the issue resolved? What was it?
Old Sep 5, 2021 | 08:18 AM
alain's Avatar
hello
first : sorry for my english (i'm french).
I had the same problem 2 or 3 months ago on my discovery l319 from 2006, the lights came on one after the other after 10 kilometers.
no error code in the suitcase, I checked the abs sensor the bulbs and other according to what I found on the forums.
As a last resort I tested a solution that did not quite resemble my symptoms:
Reinitialized the steering wheel centering sensor with the suitcase and the mongoose cable for 5 minutes and everything returned as if by magic, since I have not no more worries.
RRM
Range Rover L405 (Fourth Gen)
Dec 27, 2020 09:22 AM
csohkrisztian
LR2
Dec 11, 2020 01:38 AM
overlandrover110
Nov 6, 2020 03:27 PM
redinak
Jul 13, 2020 11:07 AM
