Another Weird Suspension Issue
Old Jan 31, 2014 | 08:39 AM
taylorm334's Avatar
Default Another Weird Suspension Issue
During the snow storm this week I went to raise my LR3 to off road height and got a suspension fault. I restarted the car and it went away, but would come back randomly for the next 24 hours.
Now on cold startup, the compressor runs fine and fills up the reservoir and levels the front, but once the rear raises the fault goes off and stays on. Its been doing this for 3 days. It drives fine and stays at the correct height, but the fault dings over 30mph and runs fine at 70 mph, just dings a lot.
I don't think is the compressor, its only 18 months old. Any thoughts on why the fault happens when the rear goes to raise???
Old Jan 31, 2014 | 09:39 AM
houm_wa's Avatar
Always start with the battery! Beyond that, I'm not sure without more info. Are you saying that you raise to O/R Height, get the fault, it drops you back to Normal Height but that the icon remains illuminated and you get a "reminder" above 30 MPH? Is the icon red or amber?
First blush is that it could be a wacky height sensor resulting in an out-of-range fault.
Old Jan 31, 2014 | 09:53 AM
taylorm334's Avatar
Battery is only 7 months old and reads perfect. It will not go into O/R height. It will start to raise then throw the amber code. Then when I go over 30 mph it turns red, but nothing happens, it just beeps and stays lit. Would an height sensor cause this?
Old Jan 31, 2014 | 10:58 AM
jafir's Avatar
You'd really need to read the codes to see why the computer is upset. Is there anyone nearby with a hawkeye or nanocom you can use?
I think the guy that makes the abs amigo makes some software you can run on a laptop with a USB-OBD2 dongle that will also be capable of reading codes. That's probably the cheapest way to go at the moment, but the software doesn't list many advanced features at the moment, but I assume it's only a matter of time before he adds them.
4Dcan Diagnostic Tool
Old Jan 31, 2014 | 08:58 PM
unseenone's Avatar
If I were to start diagnosing on this problem, I would be checking wheel speed sensors, wiring. I would check for ice or something on the height sensors or the height rods. Perhaps a sensor height or speed has gone bad.
Typically in the snow belts you can find a decent car wash that does the under body.
Do you have NAV, put it on the 4x4 screen while driving and see if one wheel goes bonkers or anything looks out of the ordinary when the pinging starts.
Beyond that, taking it to a good independent or dealer who can read the codes and see what the fault is might be useful.
You mention the front raising, then the rear. It works just the opposite for me. There are two valve blocks that get plugged up one for the front, one for the rear. Perhaps it can be cleaned or replace if that's the issue.
Old Feb 2, 2014 | 12:48 PM
taylorm334's Avatar
Problem solved! My front cross link valve came unplugged. The clip broke, so I zip tied into place and restarted the LR3, no more faults and Its all working 100% now!
Old Feb 2, 2014 | 12:50 PM
jafir's Avatar
Nice!
taylorm334
Dec 27, 2013 09:34 PM
idagon
Dec 9, 2013 03:13 PM
DiscoPhipps78
Jan 3, 2013 07:42 PM
Hyakku
Sep 17, 2010 08:49 PM
khtemple
Sep 14, 2006 06:00 AM
