Battery Replacement
Any premium battery that matches vehicle is good. Everybody has there own specific manufacture, but all are pretty much made in same factories anymore. Warranties differ. I had an Optima in my race car, took out after 7 yrs. and put in a new battery that was not Optima and weighed less. Same install as anything else, turn off for a few minutes. Negative cable off first then Positive. Positive back on first then Negative. Clean terminals of cables good and check and additional wires to cable ends for corrosion, then add drop of oil to each fastened terminal to hold off corrosion. If they give you the red and green felt pads oil them very lightly as you put them on.
arrkerr
Dec 14, 2005 10:06 AM
