Bi xenon adaptive headlamp help!
Old Jan 14, 2010 | 11:34 AM
tibetrover's Avatar
Default Bi xenon adaptive headlamp help!
so i have a used 2006 lr3 hse, i noticed that the front headlight on the drivers side wasnt as bright as the passengers side, and after looking closer at the light i noticed that the beam of light on the drivers side was slightly lower then on the other side, so to me it seems that i need to adjust the shield (if there is one) to straighted out the light... but i dont know how to do it, and when i asked the landrover master repair guy at the dealer here, he acted as if there is nothing that i can do, but where i bought it vehical from they said that the dots on the headlamps are from adjusting the lights... so now im kinda confused...... HOW DO I FIX THIS !? and is it actully the beam of light or the needing of replacing the light it self?
Old Jan 16, 2010 | 10:26 AM
Rovin4life's Avatar
maybe fiddle with the parts in the back or maybe its not seated correctly. they are easy to take out, take off the center grill and then pull up the tabs and pull out the units and see if anything is off.
Old Jan 19, 2010 | 12:03 PM
tibetrover's Avatar
ahh ok sounds good, and what is the best headlights if i want to replace them? like oem vs other brands???
Old Jan 20, 2010 | 06:01 AM
Rovin4life's Avatar
150 from Ab AND 400 From the dealer. if its still under warrantee complain and they might give you a new one for free.
Old Feb 2, 2010 | 08:48 PM
Navy_Jak's Avatar
tibetrover,
I have an 06 LR3 HSE and its doing the same thing but on the passenger side. It has been adjusted (no cost) 4X at the LR dealer. It would be fine one day but after a week it lowers back down on its own about 3-5 degrees.
It does not really bother me that much, it just look like I don't have zenon on one side. I'll address the issue again on my next scheduled maintenance, maybe they will replace the entire set. I have the AFS and it's not the zenon bulb either. My warranty expired last Nov but I have an extended warranty.
Oasisplayer311
Sep 30, 2017 03:59 PM
snowplower
Sep 10, 2009 07:59 PM
hleo1
Jul 17, 2008 06:39 PM
Ethan Hunt
Oct 17, 2007 09:20 AM
1ozeme
Apr 4, 2006 01:10 AM
