Big Plans
Old Dec 27, 2013 | 08:35 PM
  #21
houm_wa's Avatar
Nice!
Old Dec 28, 2013 | 08:57 AM
  #22
jnorton1's Avatar
Looks nice.
Old Dec 28, 2013 | 08:16 PM
  #23
spiderman's Avatar
Originally Posted by DiscoBreck
Got my 275/65r18 Nitto Teera grapplers and I love them.
Probably a wise choice on tire size and tread pattern. They measure out to be around half an inch smaller diameter than what I am running and there is no aggressive side lugs to rub the upper front control arms. BUT, as mentioned previously, I fully expect them to rub in the wheel wells in situations such as this:
I understand that this is clearly set up on purpose as a test, but if you really go off-road, it is not that hard to find yourself in a similar situation. I highly recommend that you remove the mud guard/wheel well liner on the right rear in order to locate, inspect, and understand the consequence of rubbing through/puncturing/or kinking a coolant line. The lines in the front of the wheel arch are feed and return coolant lines for the rear heater (the A/C lines are run in the left rear wheel arch.
It looks great. Get out there and have some fun, but make wise decisions on where you go and have a buddy on speed dial for those time it just doesn't work out.
Old Dec 29, 2013 | 10:13 AM
  #24
DiscoBreck's Avatar
I'll look into that. I probably won't be doing any serious off roading until I have the car for a few moths and truly know it's capabilities which I know it has a lot and that's why I'm looking into everything more and waiting it out compared to how I did with my D2 which I took off-row immediately haha
Also how'd that happen to your car?
Old Dec 29, 2013 | 04:24 PM
  #25
spiderman's Avatar
The plan was to drive off to the right, but there was a log on the bottom that was quite slippery and I couldn't get over it. It ended up pushing me into deeper water and then when I tried to reverse up the bank the gravel was too soft. I had to call a buddy. My carpet in the driver's footwell was wet for 2 weeks. I've been having a lot of trouble lately, it may be because it was sunk, or it could be unrelated.
SGT Disco II
Mar 19, 2014 07:10 PM
luxury1
Dec 13, 2008 04:12 AM
sailorcolin
Feb 22, 2008 03:34 PM
mdvickst
Mar 6, 2007 01:30 PM
traffictech870
Sep 5, 2005 04:13 AM
