Bigger picture - What do these faults point to?
Old Jul 5, 2019 | 05:53 PM
Philip Chan's Avatar
Default Bigger picture - What do these faults point to?
I love using this GAP tool! Where else can I be constantly and consistently disappointed!
Although I have specific errors that pop up - such as the airbag seat sensor and Seat Heat (I think there is a break somewhere) I'm wondering if looking at all the error holistically point to something that, when fixed or replaced, alleviate these problems.
Thoughts would be appreciated:
Airbag
  • B00C0-96 (AC) Passenger's seat occupant classification sensor A - Component failure - internal failure
    ( on 04-07-2019 09:44:07 at 202420 km )
Audio Amplifier
  • B1A96-68 (2C) Bus still active after shutdown request - Algorithm based failure - event information
Body Control
  • B1A98-83 (6C) Local interconnection network bus circuit 1 - Bus signal/message failure - value of signal protection calculation is incorrect
    ( on 25-06-2019 16:43:27 at 201834 km )
  • B1A99-4C (64) Power on reset
    ( on 25-06-2019 15:06:37 at 201834 km )
  • B1B02-28 (2F) Low frequency coil - General signal failure - signal bias level is out of range/zero adjustment failure
    ( on 25-06-2019 16:44:11 at 201834 km )
  • B1BA0-66 (6C) Excessive challenge requests or start attempt in storage mode - Algorithm based failure - signal has too many transitions/events
    ( on 02-07-2019 20:06:30 at 202274 km )
  • B1C44-67 (68) Rear wiper park position switch - Algorithm based failure - signal is incorrect after the event
    ( on 27-06-2019 12:44:59 at 202104 km )
  • B1C45-67 (68) Front windshield wiper park position switch - Algorithm based failure - signal is incorrect after the event
    ( on 27-06-2019 13:44:14 at 202114 km )
  • B1C57-14 (6C) Passive start ignition relay coil circuit - General electrical failure - circuit short to ground or open
  • B1C82-14 (2C) Headlamp washer relay coil circuit - General electrical failure - circuit short to ground or open
    ( on 25-06-2019 16:43:28 at 201834 km )
  • B1C96-13 (2F) Alarm LED circuit - General electrical failure - circuit open
    ( on 25-06-2019 16:58:40 at 201834 km )
  • B1D05-15 (2E) Lower tailgate release circuit - General electrical failure - circuit short to battery or open
    ( on 27-06-2019 19:17:47 at 202194 km )
  • B1D13-15 (2E) Interior lamps 1 circuit - General electrical failure - circuit short to battery or open
    ( on 25-06-2019 16:58:28 at 201834 km )
  • B1D14-15 (2E) Interior lamps 2 circuit - General electrical failure - circuit short to battery or open
  • U0155-87 (2E) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message
    ( on 25-06-2019 16:54:52 at 201834 km )
Engine Petrol
  • P0170-00 (E8) Fuel trim (bank 1)
Instrument Pack
  • U0102-87 (24) Lost communication with transfer case control module - Bus signal/message failure - missing a message
  • U0132-87 (2E) Lost communication with ride level control module - Bus signal/message failure - missing a message
Rear Diff
  • P0806-00 (2F) Clutch position sensor - circuit range/performance
    ( at 0 km )
  • P080A-00 (2F) Clutch position is not learnt
    ( at 0 km )
  • P0810-92 (28) Clutch position control error - Component failure - performance or incorrect operation
    ( on 04-07-2019 12:41:58 at 202436 km )
Vehicle Dynamic
  • U0424-68 (08) Invalid data received from heating, ventilation and air conditioning control module - Algorithm based failure - event information
    ( on 05-07-2019 10:40:11 at 202480 km )
Ventilation
  • B1A73-18 (6C) Left seat heater - General electrical failure - circuit current below threshold
    ( on 04-07-2019 09:48:07 at 202420 km )
wehtjns
LR4
16
Jan 30, 2024 02:41 PM
Rufflyer
Aug 12, 2019 07:45 AM
Atticus_6147
Jun 5, 2019 03:24 PM
LRD2rangel
Oct 15, 2018 11:34 AM
Phifross
Jun 7, 2017 07:58 PM
