Brake Cable in the EPB Module
Old Feb 14, 2021 | 12:01 PM
Island Time's Avatar
Default Brake Cable in the EPB Module
Vehicle: 2006 LR3 HSE
We replaced the gears in the EPB module along with the brake cables to the rear wheels.
Installed everything back in the vehicle and set the park brake shoes as specified.
Activated the ebrake switch and the ebrakes came on-have not caliprated the module at this time.
Pulled the manual ebrake release cable to see if it worked-it does.
My question now is what is the procedure to get the ebrake cables reattached inside the EPB module?
I assume once the above is done, then will need to recalibrate the system to have the ebrake function as designed.
Old Feb 14, 2021 | 01:52 PM
DakotaTravler's Avatar
I am guessing you adjusted the parking brakes without first activating the system, so the module could have been in the wrong position for setting them with the torque wrench. Also the release does not detach the cables.
Watch this:
Read the attached file.
delormea397
Dec 18, 2018 04:55 AM
redwhitekat
Apr 17, 2018 02:43 PM
djkronik57
Feb 6, 2018 02:25 PM
astarrdemille
Sep 6, 2013 08:25 PM
bamaboy473
Aug 3, 2012 06:33 AM
