Brake light, ABS Sensors, WHAT ELSE!
Old Apr 21, 2015 | 12:24 AM
Oasisplayer311's Avatar
Default Brake light, ABS Sensors, WHAT ELSE!
Like the title says, im planning on replacing some things before my "Thousands" (yes, with an "s") mile journey. Ive been getting some weird shifting lately (really high RPM's before switching gears) and (radiator fan will spin VERY FAST when im trying to get out of first gear) also (Hard down shifting) Hoping the Brake Light Switch and replacing the rear Brake Lights will help.
So my questions are: What else!
> what brake light switch do i need?
> what brake lights do i need?
> What and why do i need to replace ABS sensors?
> My Compressor seems to run long, and turns on EVERY TIME I start my LR3, What should I check or replace? (I have the AMK Compressor)
Thanks guys!
Your friendly neighborhood Rover
Eric
Old Apr 21, 2015 | 06:26 AM
Ghaniba's Avatar
Curious, have you checked the rover for codes? For the record, I wouldn't trust my rover for thousandS with an S when it WAS behaving, nevermind when it was already showing signs of an excuse not to work. Granted, I'm still jaded from my D2 which left me stranded more times within 6 months than any vehicle I have ever owned in my life.
But seriously - I'd have someone with an IID tool or something scan it and see if there's any codes that could be informative of an impending problem. I was amazed by how much was in mine for codes without a single light on the dash illuminated.
Dave
Old Apr 21, 2015 | 09:56 AM
WNYErikDiscoII's Avatar
Former Sponsor
Your compressor will run every time you start the truck. Even the brand new trucks with brand new AMKs run every time. Its basically a system check and to get everything to standard operating pressure. As for the shifting. I would check your transmission fluid level. I do not think changing your brakelight switch and bulbs will help your transmission problems, but then again it is an LR3 and nothing surprises me anymore. Usually those items are more common with warning codes such as loss of special programs, suspension riding at access height, etc.
If you feel your suspension runs too often, spray some soapy liquid on the front and rear valve blocks, on top of the air bags and the crosslink valve. Start the truck, raise to Off Road height and check for bubbles.
To replace your ABS sensors, I wouldn't touch them unless you need them. If you do, you obviously need new sensors and a handful of ANR2224's as you'll likely break some removing the inner fender splash guard.
Old Apr 21, 2015 | 10:51 AM
houm_wa's Avatar
I don't think the fan running like that is abnormal, either. There is also a trick you can do to reset certain adaptations by holding down the gas pedal with the key in a particular position (I think II) for 10 seconds I believe, then shutting the vehicle down until it's quiet, dark (or 2 minutes). Sounds whacky but it works.
I took my LR3 on a journey of ~1800 miles last March, which included a 3 day ferry ride, -17F temps, ice, snow, slush, rain and Yukon-quality gasoline. It did just fine.
Old Apr 21, 2015 | 02:39 PM
unseenone's Avatar
Start Here--
XKB500110 Stoplamp switch, range rover sport 2006 - 2010 Should be under 15.00 for OEM
XZQ000020 - EXTERIOR BULBS LR3; Rear Tail/Stop Lamp Bulb three bucks or so.
Old Apr 21, 2015 | 08:08 PM
Originally Posted by unseenone
Start Here--
Is OEM what I want? Or should I go with aftermarket?
Old Apr 22, 2015 | 05:30 AM
Ghaniba's Avatar
Where are you finding the switch for under $15? Cheapest I'm finding is $39 on fleabay.
DaveM
Old Apr 22, 2015 | 07:38 AM
cmb6s's Avatar
Not sure I've ever seen it for $15, but OEM switch is Ford Motorcraft. You can find one on Amazon for about $20.
Old Apr 22, 2015 | 09:19 AM
unseenone's Avatar
Wow, your right the price has shot up for no reason, I suspect it would be because they know everyone will need at least one. The last time I bought a 2-3 years ago, it was $11.96. I would go Motorcraft or OEM, not aftermarket. It's 33.00 here.
Old Apr 22, 2015 | 10:28 AM
Former Sponsor
I sell the OEM one for $17/delivered all day.
Im still curious as to why you're doing what you're doing when you have a rough shifting transmission issue.
