Brake light issue
Old Aug 11, 2024 | 04:58 PM
edburrow's Avatar
4th Gear
Default Brake light issue
2007 LR3 HSE. Brake lights work as designed when headlights are off. When headlights or DRL are on the right rear light does not work. In fact both elements (filaments) go out when brakes are applied. Replaced the bulb just to satisfy that question. Anyone?
Old Aug 11, 2024 | 08:15 PM
houm_wa's Avatar
Default Huh?
I don’t understand your question because the grammar is so bad. Just replace the bulb.
Old Aug 11, 2024 | 08:17 PM
edburrow's Avatar
4th Gear
Guess you don’t understand. So don’t reply.
Old Aug 11, 2024 | 11:41 PM
houm_wa's Avatar
What is your actual question, ********?
Old Aug 12, 2024 | 05:08 PM
DakotaTravler's Avatar
Brake light switch is defective or you have the wrong lamps. Yes, you replaced it. But you need to make sure it is the correct one for sure AND that it is in the socket correctly. The sockets are horrible (thanks Ford!) and it really is easy to install the wrong bulb and not have it seated correctly. I think the brake lamps will have double contacts on the base - which is why proper install is critical.
Trailmix
Nov 6, 2023 04:46 PM
04in719
Mar 8, 2019 12:11 PM
jaystekan
Nov 10, 2014 11:06 PM
jbarr89
Aug 7, 2012 08:38 AM
Ryan Lovely
Dec 10, 2011 08:05 PM
