Brakes done this weekend. Not so bad.
Old Sep 7, 2014 | 03:09 PM
revel8or's Avatar
Default Brakes done this weekend. Not so bad.
Howdy all. I've been remiss in keeping up with my experiences with maintenance with my LR3, so I figure that this a good place to get a late start.
It was really a pretty standard brake job, at least there were no surprises and absolutely nothing that I would consider to be "difficult." Unless you consider the weight of the rotors, as I am weak and pusillanimous.
So, what I did this weekend was:
  • changed the pads, front and rear
  • change the wear sensors, front and rear
  • changed the front rotors
  • bled the brakes (as best as possible)
  • cleaned the negative battery terminal
  • gave myself the obligatory 3mm x 3mm bleeding scratch (good for my 8 yo girl to become nurse and assist with band-aid and ointment)
I found this resource to assist me, and I'm sure that it's been circulated about, here and there, but I'll post it again:
Bodsy's Brake Bible
The front sensor seems to be subject of concern, but if you've ever changed an oxygen sensor on a mid '80's Golf, this is a piece of cake. Bodsy's guide shows how to get to it. It really isn't bad.
I was worried about the torque of the bolts that attach the caliper bracket, but I turned the wheels slightly for better access and used a cheater bar along with my breaker bar, and they came loose without bodybuilder effort. As far as reattachment, the specification is for an ungodly 200 ft/lb of torque, so I set my cheap-butt wrench to max (150 ft/lb), then gave them an extra push with my breaker bar and cheater bar afterward.
Changing the fluid was really the worst part. I wore my fingers down pulling my Autoz*** pump that I swear that I can see bone through them. It took forever, even with my wonderful assistant and master pedal-pusher (my wife) pumping the brakes. The fluid never did become as clear as I would like, so I may take it in to someone that has the necessary computer. Or I may eventually buy one of those darned things...who knows.
The only "scary" part was when I got back in the car, the display stated that there was a parking brake fault, according to the all-knowing HAL like entity. It also ran a little rough, so I assumed that the computer was playing catch-up to reality as it didn't have power for the 3 minutes that it took to clean the negative battery cable. I could hear the parking brake engage and disengage, and it would certainly stop the car if I were slowly rolling backward and then let it go when disengaged.
After a test drive to Adv***e, it was running better and the parking brake fault stopped showing up when the car was started.
I have to say, that for as much effort as it took to bleed the brakes, that's the only part that I'd farm out if I were feeling particularly lazy for a day.
So I hope this provides some reassurance if you're considering purchasing a used LR3 and want to do your own maintenance.
Old Sep 7, 2014 | 06:37 PM
Scope's Avatar
Good write up and Congrats on all the money you saved!
glassman66
Jul 17, 2012 08:31 AM
GamecockRover
Jul 16, 2012 02:00 PM
FightOnUSC79
Nov 26, 2010 09:43 AM
kfx4001442
May 18, 2008 09:50 PM
fridgefreezer
Mar 3, 2007 10:42 AM
