buying a LR3
Old Jun 23, 2016 | 10:40 AM
ninjaff21's Avatar
Default buying a LR3
I have owned a discovery 2 previously and now am looking into a LR3. Looking for some insight from current owners.
From my understanding the common issues are:
1. Control arm bushings (check for tire wear)
2. Air compressor
3. brake switch
4. Sunroof drains
My biggest concern is the transmission though and haven't found much on this. do these units completely fail rarely or are they a common issue? I'm aware of the need to change the fluid the second i purchase the truck.
Old Jun 23, 2016 | 10:51 AM
houm_wa's Avatar
There haven't been a ton of tranny failures reported here at least...or other forums, over the last 10 years. There can be leaking from the mechatronics sleeve (I think I got that right) but other than that they seem good. Add differentials to your list, especially on an earlier model year. Drive it and listen for any groaning, and change the fluid when you buy it.
Old Jun 23, 2016 | 12:41 PM
TOM R's Avatar
Look at the sticky for pre check to buy lr3, tranny seem solid when serviced
Wet passenger front floor is the biggest thing
Old Jun 23, 2016 | 01:50 PM
ninjaff21's Avatar
my old d2 sunroof would always leak very annoying. v6 vs v8 if you had to pick which one?
Old Jun 23, 2016 | 04:10 PM
houm_wa's Avatar
V8...
Old Jun 24, 2016 | 09:33 PM
TOM R's Avatar
Clogged leaking sunroof on lr3 soaks floor shorting wire harness disabling vehicles , d2 vs lr3 isn't even apples and oranges like rock and orange they are so dissimilar the only thing they share is the green oval
Old Jun 26, 2016 | 10:42 PM
Volkov's Avatar
Leaking mechatronic sleeve is the only common transmission problem. Oh, and the california stop hard shift. The first is somewhat difficult to fix the second is just a software update from GAP
nh9095
Jan 14, 2019 12:36 AM
npgdrums
Oct 9, 2008 05:43 PM
irocdaparty
LR2
Jun 4, 2008 07:40 PM
99discoII
Jan 15, 2008 08:59 PM
steveo
Jun 6, 2005 03:03 PM
